April 12, 20206 yr I am trying to either print a copy of my vault or export it and I can seem to find any documentation on how that is done. Can anyone help me out there.
April 14, 20206 yr Hi @Butch, Thanks for using Enpass and writing to us. Currently, you can print or export the data from Enpass Desktop version only by following the below steps- To Print -->Open Enpass --> Click on 'File' Menu --> Tap on 'Print' --> Select the item or vault --> Print. To Export --> Open Enpass --> Click on 'File' Menu --> Tap on 'Export' --> Select the item or vault --> Export. Thanks!
