Syncing with Nextcloud (Linux client); solved
When trying to sync with Nextcloud this does not work:
https://your_cloudurl/remote,php/webdav
Adding remote,php/webdav is shown as reminder in the dialog box.
I almost gave up, but now I found that this works:
https://your_cloudurl/remote,php/webdav/
It would be nice if either input would work
Hi @cbaurtx,
Welcome to the forms!
 I have noted down your feedback, so thank you for getting in touch. I shall pass your comments onto our development team.
Thanks!
Thank you so much. If there is anything else I can help with, please let me know.
