April 21, 20206 yr Is there a way to edit what shows in the secondary heading? Not sure if that's what it's called; in pic (#1) the "emily@enpass.io" under Facebook. Some times it's username or times it's the website. Would be nice when showing all vaults to have it be the vault name when having multiple sign-ins between vaults for 1 site, like at #2.
April 22, 20206 yr Hi @dp917, Thanks for using Enpass and writing to us. (pic #1) I would like to share that Enpass always uses the 1st line of the item detail page to display in the saved item list, you can change the 1st line from username to website, email or anything just by scrolling the line on the top(1st line) from the item edit page. (pic #2) The second heading shows the vault in which the item is saved. You can copy/move (Duplicate or change) the item saved in some particular vault to other vault. You can also refer this link to know more. Quote Would be nice when showing all vaults to have it be the vault name when having multiple sign-ins between vaults Also, I have noted your suggestion to show the vault name under the particular login all items list. Thanks.
