Autofill doesn't pick the right entry
I am using enpass on desktop with firefox.
In enpass, I have 2 entries:
  • domain.de/typo3/index.php (1)
  • domain.de/typo3/install.php (2)
I open domain.de/typo3/index.php, press the shortcut for enpass.
Expected behaviour:  entry (1) gets filled in
Current behaviour: Enpass opens a popup and lets me manually choose between the two entries.
Is there a way to configure enpass to show the exprected behaviour?
Hi @Nicolai,
Currently, if you have enabled Match URL hostname in Enpass browser setting, it only checks the domain if the URL. There is no option to check the subdomain of the URL in Enpass.
Hi Pratyush,
thanks for your quick answer.
Could you add my expected behavour from above to a whishlist?
Enpass constantly asking which entry to take, when choice is evident, is really annoying...
Hi @Nicolai,
Thanks for writing back in.
We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
