August 27, 20179 yr How may I copy an item? I'll bet it's easy. I just haven't found it. I have an item with several custom fields. I'd like to create a second item, with the same fields, but different information. It'd be a whole lot easier if I could just copy the first item, change he information in the copy, and go on my merry way. (As opposed to creating a new item, adding custom fields, re-arranging them in a special way, adding a custom icon, and so on…). Did I miss something in the documentation?
August 28, 20179 yr Hi @fjpoblam, Not an issue! You can create a Duplicate copy of your customized item with all the fields and data which you can edit with new details. Hope this helps!
