Disable Autofill When Using Google Messages
Hello,
Is there a way to disable autofill from prompting when using the Google Messages app on Android? I am using a OnePlus 7T running Android 10.
If I turn off Autofill in Enpass it does not show up. But I need it to prompt for the other apps.
Thank you.
2 minutes ago, Roehl Aguila said:
Hello,
Is there a way to disable Autofill from prompting when using the Google Messages app on Android? I am using a OnePlus 7T running Android 10.
Thank you.
Edit : Sorry for posting this in the wrong thread. :(
