September 7, 20179 yr So Enpass is an offline password manager. But if you decide to sync your data, you have to use the cloud because you can't use Wi-Fi sync. I have to store my container on services like iCloud or Google, Dropbox if I want to access it from all my devices. Enpass is missing a 2FA. If somebody is able to access my cloud or hack the service I‘m using, he can steal my container. Enpass only offers a master password and nothing else. It can be hacked more easy than having a second factor. Any plans on adding such a feature in the future? Edited September 7, 20179 yr by Chippelchen88
September 8, 20179 yr Hey @Chippelchen88 As you said Enpass is an offline password manager and we don't keep any of your data with us. So it's not technically possible to enable 2FA for Enpass. But all the cloud services you mentioned support 2FA, you can enable 2FA for the cloud account. It won't affect the behaviour of Enpass in any way. Cheers!
September 25, 20179 yr On 9/8/2017 at 11:04 AM, Akash Vyas said: Hey @Chippelchen88 As you said Enpass is an offline password manager and we don't keep any of your data with us. So it's not technically possible to enable 2FA for Enpass. But all the cloud services you mentioned support 2FA, you can enable 2FA for the cloud account. It won't affect the behaviour of Enpass in any way. Cheers! there is however an option to add key-file support as a second factor for authentication, like other non-cloud based password managers have.
September 25, 20179 yr Author 6 hours ago, intuxikated said: there is however an option to add key-file support as a second factor for authentication, like other non-cloud based password managers have. How?
October 4, 20179 yr On 9/25/2017 at 8:38 PM, Chippelchen88 said: How? the comment was meant towards Enpass developers, they can implement key file support in the current version there's no way yet to use a key file as a second factor
