May 31, 20206 yr Hallo Enpass Team besteht die sichere möglichkeit eine 2 Fach authentifizierung über Enpass zu ermöglichen Beispiel man will Enpass öffnen braucht aber Masterpasswort gleichzeitig aber einen 6 stelligen code auf das Handy
June 1, 20206 yr Hey @enpass pin Thanks for using Enpass and writing to us. Please refer to this FAQ . However, to add extra randomness to your Master Password, you can use a KeyFile in Enpass. A KeyFile gets appended to your Master Password before the actual encryption or decryption of your data happens. So, even if someone, somehow gets access to your data and your Master password is also compromised (a worst-case scenario), your data is still safe as the Key-file (stored on your device) is required to decrypt your data. For more details, please refer to this link to our user manual page. Thanks.
