June 5, 20206 yr I installed npass as directions showed https://www.enpass.io/support/kb/general/how-to-install-enpass-on-linux/ and the program installed as it shows up in the menu however it will not open period when clicked on. I also installed the browser addon and it says it's unable to communicate with the program. This is my first time with this software so I hope I just missed something. Edited June 5, 20206 yr by chke419
June 8, 20206 yr Hi @chke419, Sorry for the inconvenience caused to you. I have noted down this issue and notified the team to look into it.
June 14, 20205 yr Are you getting a specific error? If you run it from the command line via "enpass" command what errors or output is generated?
June 15, 20205 yr Hey @chke419 Please have a look at this forum post and revert us back if you have any query or if the issue persists. Also, please refer to this FAQ to know how to install plugin. Thanks.
