June 7, 20206 yr Dear I can't synchronize my enpass with Gdrive. I tried reinstalling enpass with apt purge enpass followed by apt install enpass but that doesn't solve my problem. When I try to synchronize, it seems to tell me that it has no internet access but the PC is on the internet... Best regards
June 8, 20206 yr Hi @regis003, We are sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Are you getting any error message or code during sync? If yes, share it with us. Does the Date and Time setting set to automatic on all devices? Does the last synced time get updated on the sync page? Are you using any Antivirus or third-party security-related extension?
