Enpass generate not valid TOTP
I'm getting authentication error when I try to use TOTP generated with Enpass seams that the codes that it generate are not valid.
I've tried with Github and with Gmail and I have the same error the codes are not valid.
This is strange since I used it since last month.
Hi @gspe
Sorry to hear about the trouble. This problem surfaces when the date and time on your devices don't match internet time. So please make sure that date and time are accurate on all devices (preferably set to automatic).
Hope this helps!
Thanks that was the problem, I don't know why time sync stopped on my system...
Now works correctly.
