August 10, 20206 yr I just installed Enpass from enpass.io on a new Ubuntu 20.04 installation (Gnome desktop). When I try to open it, a black bar with blue lines appears at the bottom of my screen and the system locks up for a while. I've attached a screenshot of the desktop and the ~/.config/sinew.in/Enpass.conf file that executing Enpass creates. (Was previously using Enpass on OpenSUSE 15.2 Tumbleweed with no issues.} Any ideas how I can resolve this? Edited August 10, 20206 yr by John P changed text layout; was obscured by image attachment.
August 10, 20206 yr Hi @John P If you launch Enpass from the command line does it generate any error messages? Just for comparison here is my Enpass.conf from Xubuntu 20.04: [General] DEVICE_UUID=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx DIALOG_LAST_OPEN_LOCATION=/home/user/ DIALOG_LAST_SAVE_LOCATION=/home/user/ LAST_SELECTED_LANGUAGE=default LAST_USED_VAULT=primary MAKE_HELPER_STICKY=false QUICKSETUP_SHOWN=true SELECTED_LANGUAGE=default assets_copied1=0 detailPaneTabWidth=0 masterPaneDesktopWidth=280 masterPaneTabWidth=240 sidePaneDesktopWidth=260 [Backup] MajorCount=2 MinorCount=0 lastBackupTime=1597043857 lastMajorCountTime=1597079332 lastMinorCountTime=0 [Genaral] enableGrayTrayIcon=true [%General] autorunAtSystemStartup6=true avoidSubscriptionDialog=true hiddenCategories\size=0 useDarkTheme=true [mainWindow] height=1349 screen=DP-0 visibility=2 width=1986 x=1 y=73 Edited August 10, 20206 yr by Dentonthebear Thought to add my own config.
