August 29, 20206 yr I usually use a keyboard short to open Enpass Assistant. With time it becomes natural and handy. In rare cases I also do that because I want to modify or duplicate an item on the list (which is not supported from the Assistant). So in the Assistant I find the item I want to modify, and press the Command + E key combination to open the main window. And for me it seems natural that the item that I already found in the Assistant should be selected in the main window that opens, but it isn't. Would you consider a change here? Thanks!
