October 6, 20179 yr Die Erweiterung für Edge funktioniert nicht. Bei Aufruf soll ich diese in Edge freigeben. Habe dies erledigt. Funktioniert trotzdem nicht. Heiner
October 9, 20179 yr Hi @Heiner Thanks for writing in. As far as I understood you are facing a problem using Edge browser extension? If yes, please make sure you have installed Enpass password manager app and Enpass extension for Microsoft Edge from Windows store in your system and have Enabled browser extension in Enpass password manager browser settings. If I misunderstood the problem please elaborate a bit more.
October 10, 20179 yr Author Hi Ansuh, I have re-installed Enpass und new installen. Also the Extention. Now its all o.K. Thanks Heiner
October 14, 20179 yr Author Hallo Ansuh, Problem is back. . I have activated the extension and also released it in Enpass. However, the extension always prompts me to grant the release. Interestingly, the extension has worked in between but 2 times. Since then I have made no changes. Gruß Heiner
