September 20, 20206 yr Hi, can anyone reproduce the following error with the opensuse (rpm) repo? Fehler beim Download (curl) für 'https://yum.enpass.io/stable/x86_64/repodata/repomd.xml': Fehlercode: 'Connection failed' Fehlermeldung: 'Could not resolve host: yum.enpass.io'
October 20, 20206 yr Hey @ZZTop @csab1915 Apologies for the delayed response. Welcome to the forum! Please check if you are behind any proxy and let us know. Also, your problem could be related to an issue with your mirror (download.opensuse.org redirects you to a download mirror), with your network or DNS configuration or a number of other things. To check this, first test your DNS with nslookup www.google.com or nslookup download.opensuse.org and share your findings. Thanks!
