October 26, 20179 yr Is it possible to import from this password manager? Pocket for android by Tim Clark I cant insert his website, it says spam warning if i try. But google it Edit: Ok i found that you had Pocket in the list in the Enpass Windows program under import. And was able to succefully export from Pocket! So im very happy it worked out and im already loving Enpass! Great work guys! Edited October 26, 20179 yr by Viwa
February 15, 20188 yr I need too import from Pocket android by Tim Clark, but I have only a file with db extension . "wallet.db" It´s possible to import it? Edited February 15, 20188 yr by Benjamin Moscovich
February 15, 20188 yr Author In Pocket you have to login and click on config (im looking on the android app now) and then choose export. I dont remember which file type i choosed but one of them unencrypted i think and then enpass could handle the import
February 16, 20188 yr Hey guys, Yes, you can import the data from Pocket to Enpass. For this, you need to export the Pocket data to an XML file and then import it using the free desktop version of the app. Please have a look at the user manual to know the steps involved in importing the data. Hope this helps!
