Allow multi line text field or a Add a recovery codes field
Simply put I'm suggesting a multi-line text field that can be secured.
Sites using multi-factor authentication (MFA) often have a set of recovery codes. One can't add these easily to Enpass as I don't have an option to have a secure text field.
While talking about fields it could be nice to have a master list of fields that are already setup and can be added to any item (ie, I just add the recovery codes field I've already added).
Multiline in text field with sensitive option is good feature.
I have to use text field with sensitive option for Back up code of Evernote, Google,... they have 10 codes so I have to copy one by one and paste into text field and add blank character to separate code. It takes time.
So I think it is better if Enpass support text field with multi line with sensitive.
