October 16, 20206 yr Hi, I've just switched to Enpass and have been having some trouble getting the browser extension to autofill cPanel logins. I've got a couple of web hosts so have tried it with both and they just aren't auto-filling or offering to save (I deleted and re-tried). Not sure if it's an issue with cPanel or Enpass. I've tried on Chrome 86.0.4240.75 (Official Build) (64-bit) and also on Firefox 81.0.1 (64-bit) and it's the same problem on both. I'm running this on Windows 10 and have Enpass 6.5.0 (700) installed.
October 20, 20206 yr Hey @cometlizard Thanks for reporting this. While we are looking into the problem with auto-fill, you might want to try and update Enpass to the latest version on your system and check if the auto-fill works. Thanks.
October 21, 20206 yr Hey @cometlizard Thanks for reporting this issue. We've been able to reproduce the issue on our system and now our team is working on it towards a fix.
November 12, 20205 yr Hello, I'm facing the same issue and I can "recover" it doing a rollback. I'm using Ubuntu 20.04 Linux and I've downgraded the Brave Browser (Chromium based) Extension to 6.4 with a CRX... but it keeps updating me the extensions, so I need to remove the extension and re-install the another one... that's a shame. Can you please check your "changelog" between those two versions and look for a fix? Thank you very much. Regards
November 13, 20205 yr Hi @Toni Nuñez, Sorry for the trouble you are going through. We are already aware of this issue and our Dev team is working on it. Hopefully, fix will be available in the future updates. Till then, we will request you to please co-operate with us. Thanks!
March 4, 20215 yr Hi @cometlizard @Toni Nuñez, Thanks for your patience. We have just updated the Enpass extension to version (6.6.0) with the fix. Please give it a try and let me know if it's working.
