November 3, 20206 yr I have tested the extension from your Download Section https://www.enpass.io/downloads/ If you download it for the edge browser you will send to this adresss. https://microsoftedge.microsoft.com/addons/detail/enpass-extension-require/mliehcloacfoicbanjhhnlimealolgoi It seems to be, the extension is to old. It does not work, the browser is not trusted if you want to enable the extension. I downloadet the originial from the chrome store and this on works as it should.
November 4, 20206 yr Hey @hanny00 Welcome to the forum! Thanks fir sharing your valuable inputs. I have noted and shared it with the team. Thanks!
December 11, 20205 yr The new Microsoft Edge is based on Chromium, so extensions designed for the old version of Microsoft Edge will not work with the new version. writemyessay.onl
December 14, 20205 yr Hey @LonnySamson Welcome to the forum. Thanks for letting us know about this new implementation.
