Folder vs. Categories – help needed
Hello everyone,
I am trying to set up my Enpass according my needs, but I am frustrated by managing the folders.
Maybe I am doing it completly wrong, that’s why I am opening this topic…
What I want to (example):
I want to set up a folder with all my Online Banking accounts.
Let’s call it „Bank“ and let’s pretend I would have really A LOT of such elements in this folder and I am creating new ones quite often.
The way I understand it:
…is that I can not creat a new element for the folder „Bank“ directly in the folder.
Each time I am creating a new element I have to connect it with a category and then I have to drag it into the folder I want the element to be organized.
Problem:
Each time I am creating a new element which i want to be found in the folder „bank“,  i now have to search it under numerous of old elements in the same category, to manually drag it into the folder i want it to be. (Insane!!!!)
Question:
Is there a way to connect a folder directly with a category?
Or, even better, is there a way to creat an element directly in the folder?
Thanks in advance for your answer.
Hi @Sensaistorm
Thanks for writing in and detailed explanation.
To do so, select the folder in which you want to add the new item and now try to add the item. It will add automatically to the selected folder.
Hope this helps!
