November 18, 20179 yr The add-on for Firefox is not working on my system, it redirects me to the Enpass Connection Error help. How can I debug this, is there any way to detect what is wrong? As far as I know, it's all brand-new: Windows 10 Home Single Language Build 16299 Firefox 57.0 64-bit with Add-On Enpass Password Manager 5.5.0.2 Enpass Password Manager 5.6.2 It works fine with Chrome and Edge... Any help appreciated. John
November 19, 20179 yr +1 I'm having the same issue - other browsers work, it used to work on Firefox 56, but with Firefox 57 and the Add-On Enpass Password Manager 5.5.0.1 it always redirects to Enpass Connection Error.
November 20, 20179 yr I have the same issue and its really frustrating, its an total overhead to search the Logins and then copy and paste it...
November 20, 20179 yr I solved my issue by installing the traditional Desktop application (not the one from the store), which is still version 5.6.0. I hope that helps you as well! Can be found here: https://www.enpass.io/download-enpass-for-windows/ (in the section "Download from Website")
November 20, 20179 yr Author Thank you @islerfab, this worked for me! (One warning: Enpass does not work with Edge anymore on my system, because for that the store-app is required). Thanks! John
