November 29, 20178 yr Im having difficulty with each window in Enpass. It does not fit my screen. Starting with the 'Welcome' page the bottom links could not be seen and the window couldn't be dragged up. So, I tried various screen resolutions and moved Windows taskbar from the right hand side. That helped but only a temporary solution. Im using Windows 10, and a recommended screen resolution of 1920 x 1080. I think this problem requires a bug fix.
December 5, 20178 yr Hey @Ged It seems Enpass is detecting wrong scaling factor for your display. Have you tried enabling the High-DPI support in Enpass Advanced settings? If not, please try that and let me know the scale factor of your screen if it doesn't help. Cheers!
December 6, 20178 yr Author Yes, the settings are correct. Also Enpass is working well now that I have it up and going. (Thank you ) However, I mentioned this because the problem occurred before I had access to any settings. It occurred on the 'welcome screen.' If I wasn't determined to get in, I may have just deleted the app and gone found a different password manager. Im mentioning this so that the developers can rectify it rather than lose potential customers. Edited December 6, 20178 yr by Ged
June 13, 20188 yr When my Windows 10 display settings are scaled to 150% (the recommended setting), Enpass does not fit on my screen and the window can not be resized. This thread gave me the idea to disable the scaling for High-DPI displays in Enpass (even though display resolution is 1920*1080 on a 13" laptop). This way Enpass fits on the screen and the window can be resized, but the menu items are bunched together.
