Sync with SeaFile WebDav
Hey!
I'm using Seafile's WebDAV extension to sync my Enpass Vaults. Since some weeks I got the error code 908502. Is something wrong with the WebDAV sync method or seafile?
Hey @fibis
Welcome to the forum!
HTTP 502 refers to a Bad Gateway error which basically means some problem with how the server is configured.
Please perform the below and share the below info-
  • Try some other WebDAV server to see if this problem is with Enpass or that particular sea-file server?
  • From which version of Enpass did this problem become evident?
  • Does this happen on a specific platform/device, share the device on which you are having this issue?
  • What exact Enpass version(website or store) are you using on the Windows/macOS devices?
Note- For 1st point, there's an app called WebDAVNAV on the mac store(if the issue is on macOS) that you can try for checking.
Thanks!
