Enpass crash on log in
I get "libpng warning: iCCP: known incorrect sRGB profile
QLayout: Attempting to add QLayout "" to QPasswordEdit "", which already has a layout"
I tried converting all icons per "find . -type f -name "*.png" -exec convert {} -strip {} \;"
I don't know what changed to cause this.
Still doesn't work.
Removed and resinstalled.
Did restore and when completed I tried to login and got this "Assertion 'o' failed at pulse/operation.c:67, function pa_operation_unref()". This was in addition to the above warnings.
Pulseaudio problem?
Pulseaudio problem?
Insalled pulseaudio-gconf and it stopped crashing.
Still getting iccp and qlayout notices.
Hey @topernic
This warning doesn't impact the usage of Enpass in any way. You can ignore this. If you still face any trouble using Enpass, please drop a mail at support@enpass.io with the system information and the version of Enpass that you're using.
Cheers!
After shutting down last night it started back not working again.
Same indication as before with the "pulse/operation.c:67 being the killer.
Will email info to support. What info?
