Trinty DE PClos installation instructions needed
Hello Fellow Enpass users.
The instructions given to end users for installation seemingly is not applicable to PCLOS.
I need some help to understand how to apply them to this distro and get Enpass up and running here.
Thanks in advance
Old Heathen
Hi @Old-Heathen
Currently, the only officially supported Linux distros are CentOS 7, Fedora 27 and Ubuntu 14.04 or later (64-bit only) - https://www.enpass.io/docs/manual-desktop/prerequisites.html
You should be able to install via Yum:
https://www.enpass.io/support/kb/general/how-to-install-enpass-on-linux/
Your mileage may vary however on how well Enpass interacts with the Trinity desktop environment.
Hi @Old-Heathen,
Thanks for using Enpass and writing to us.
PC Linux OS uses a combination of apt and rpm. We do not have a compatible repository for now. However, we do have a yum based rpm repository. I wonder if you can use YUM rpm directory via third-party tool.
You can also use Enpass Portable on your system please download it from here - https://www.enpass.io/downloads/. If you face any issues let us know.
