January 3, 20215 yr Please make it possible to select no vault so that the user will always be asked in which vault they want to save. And if there is a default vault it should be the one currently selected. Otherwise it is too easy to make mistakes here and save in the wrong vault.
January 5, 20215 yr Hi @Christian, Thanks for your suggestion. I have noted it down and forwarded to the concerned desk for further consideration. Cheers!
