Fingerprint authentication
I purchased the Pro edition, when I go into Security I am missing the option for Fingerprint. Am I not looking in the right place?
Hi @cjkessler,
Sorry to hear about the trouble. I would like to let you know Enpass supports fingerprint only in Samsung devices and devices that have Android Marshmallow Fingerprint API. Please let us know which Android device are you using, so that we can help you in better way.
  • 3 weeks later...
Sorry for the delay.  I have an LG G4 on ATT if that matters.  I am on Android 6.0
Hi @cjkessler,
Thanks for you reply. I would like to let you know that Samsung and Nexus devices with Android Marshmallow have provided Fingerprint API in their SDK for the fingerprint sensor, but LG G4 doesn't provide any SDK for the same, so we can't support it until it is available for us to integrate.
Cheers!
  • 5 weeks later...
Hi @cherish tota,
As already mentioned,
In your case (Lenovo vibe X3) doesn't provide appropriate APIs for the same, so we can't provide fingerprint integration.
  • 3 months later...
wait a sec, dont google's guidelines Marshmallow iirc enforce the use of the Android native API for fingerprinting on devices with it?
