Extension does not recognize some sites
I'm usering Chrome and Firefox and both extensions fail to recognize some sites. For instance  "http://fritz.box/" (within my local network) will not be matched.
Hey ScottT, we are sorry for the trouble you are facing. We are very keen to help you but as the site is on your local network we cannot debug it to see the underlying problem. Can you save the page as web archive and mail the zip of that folder to the support@enpass.io, so that we can investigate the problem.
Same here. When i try to login at the university page, Enpass is not autofilling it. Also if I search manuelly the enty and double click on it, it will not fill in the password.
What can I do?
Hi Edenhaus,
Please drop us an email at support@enpass.io with details of your device, Enpass version and Web URL of University, so that we can investigate the problem.
  • 3 weeks later...
Windows 10 SL Home 64bit / Google Chrome 64bit / Mozilla Firefox 64bit / Enpass (Desktop version)
unable to detect the email address field while signing in Yahoo!
checked from both browsers
Hi @Mehul
Thanks for reporting the issue. We will try to fix this issue soon in future version. Till then we request you to please bear and cooperate with us.
