Improve TOTP in browser extension
For sites that have a TOTP entry, it would be quite helpful to have an autofill option for the code, or at the very least have the code visible in site entry of the extension menu (not the info submenu).
Edited by MrDrMcCoy
Naming clarity
  • 2 months later...
TOTP passwords are auto-copied to your clipboard in the desktop browser version.
However, this feature isn't implemented on iOS.  When using the "share" extension to use Enpass to auto-fill username and passwords, the TOTP code is not copied to clipboard, meaning you have to open Enpass/use the share extension a second time to get the TOTP code.  This is a "must have" feature, and one your competitor implements on iOS as well.  Please, pretty please, add auto-copy of TOTP to clipboard on mobile!
