June 29, 20215 yr I understand the point of Enpass is to only have 1 password for everything but the point of a TOTP in theory is to require a second piece of information. I think Enpass should have the option to allow users to protect TOTP codes with a second, separate, master password so it can effectively function as an independent TOTP manager
June 30, 20215 yr On 6/29/2021 at 10:24 AM, el613 said: I understand the point of Enpass is to only have 1 password for everything but the point of a TOTP in theory is to require a second piece of information. I think Enpass should have the option to allow users to protect TOTP codes with a second, separate, master password so it can effectively function as an independent TOTP manager Couldn't you just create a second Vault with an different password to just use for the TOTP?
