August 6, 20215 yr Hi, i've exported my local tresor (on my Mac) as an josn File, but which way i can import this into my android app ? Can everybody help me? regards chris
August 9, 20215 yr Hi @Chrism, Welcome to the Enpass Community. In Android, there is no import option but Enpass lets you sync your data with other devices through any of the supported clouds. You can synchronize your Mac with your Android by following steps: Open Enpass on your Mac --> Click on ‘Settings’ -->Click on ‘Vaults’ --> Select the vault which you wish to sync → Select ‘Set up Sync’ and choose the cloud account--> Enter your cloud account details, follow the instructions and wait till the sync is done. For more detail refer to this link. Now after installation Enpass on your Android--> “Welcome Screen“ will appear-->Click on Restore from the particular cloud with which you have synced in step1 --> Login to the cloud account--> Click on Continue --> Follow the instructions. For more information refer to this link. Once this is done, the database from your Mac will be synchronized with your Android device.
