August 13, 20215 yr Without subscription, you only have 20 entries available for the mobile app. Now, there are some entries I use on mobile and others which I do not use on mobile. 192.168.0.1 So my question is....Is there a way to decide which 20 entries the mobile app should store? routerlogin Edited August 17, 20215 yr by kalinmiya68
August 13, 20215 yr Hi @kalinmiya68, We would have loved to help you but it is not configurable in Enpass. Thank you.
March 28, 20224 yr That limit is to support very small dataset for free, it's probably not a priority for Enpass to allow user to provide configuration for that, it would require database-scheme upgrade for all users just to support free users. Having more than 20-25 items is meant to lead to subscription
