August 14, 20215 yr Hi, I use Enpass 6.6.3 and have two "Vaults" (tresor in German) or whatever the english phrase is. Both are synced using iCloud. Now something strange happens: I add a new entry to one of the two "Vaults" sync over iCloud when the other vault is synced, it also contains the new entry! it does not always happen at the first sync. but it happens eventually. this is really strange. This is especially annoying when syncing to other devices, first I thought it is related to that. But it also happens locally...
August 14, 20215 yr Author I am not sure, it is related to iCloud sync now. It seems, when using several vaults, this happens - I saw it just happen, the sync did not yet took place... maybe this is related to several vaults, and not the sync.
August 15, 20215 yr Hello @Zagdul! Welcome to the Enpass Forum. Each Enpass vault must be synced to different cloud account, otherwise items will be mixed up. Make sure you have synced both the vaults with a different iCloud account or another cloud account. Also, you can check item of a specific vault as show in screenshot. Let us know if there is a mixup.
August 16, 20215 yr Author ok, I do only have one iCloud account. That is causing the trouble then? Interesting. Was not aware of that. So, if you want to have several vaults, you also need several iCloud accounts or sync them in different ways? I saw the icon, that's how I found out about the duplication of items. Thanks for the info!
August 18, 20215 yr Hello @Zagdul! Yes, If you are using multiple vaults, then each vault needs to be synchronized with a separate cloud account. Although, by different cloud, we mean different accounts, not services i.e. you can have multiple accounts on Dropbox and set up sync of the different vaults with them. For more details on multiple vaults, I would suggest you visit User manual.
