August 22, 20215 yr Hi guys, I've recently moved across from 1PW and everything works fine so far on my Mac, except my login for the National Australia Bank Transact website (https://transact.nab.com.au/nabtransact/) This website requires three fields to be completed and although the first field (J_subaccount) has come across fine from 1PW (where it had the same field name), it is not filling when I double click the account entry in Enpass. The other two fields complete okay, but without the first the login doesn't work. Is there some way I can fine-tune this in Enpass? ecca Edited August 22, 20215 yr by ecca
August 23, 20215 yr Hi @ecca Welcome to the Enpass community! You can autofill multiple login details by first saving the details as Webform. When on the website, fill the fields - Client id, Username and Password. Then click on Enpass extension on your browser -> Hamburger Icon(Menu) -> Save Webform . This will save all 3 details as Webform . Next time during the autofill, please select the item of webform which you saved. Hope this helps !
August 24, 20215 yr Author Thanks for the suggestion, @Abhishek. This worked a treat after I deleted the old entry that had come across from 1PW and created a brand new webform. Case closed Edited August 24, 20215 yr by ecca
