September 21, 20215 yr Now that iOS 15 is out, you might want to look into creating an extension for Safari on iOS. It looks like you'll get much better integration and a better password experience that way.
September 22, 20215 yr I am really look forward to the extension as well. 1Password already has it live ! Also there is a bug on iOS 15.. previously i could open password protected pdf’s from mail on iOS, but choosing the password from enpass - but now that doesn’t work
October 18, 20215 yr On 9/21/2021 at 7:56 AM, Discordant said: [...] an extension for Safari on iOS [...] much better integration and a better password experience that way. @Discordant posted exactly what I was going to. (I'm happy I searched before posting.) Sounds 100% correct to me.
February 28, 20224 yr Hi. Any further news on this extension the thing I am missing is that I don’t get a prompt to save new a login or updated password on Enpass. I only get the alert on iCloud Keychain. With the ios 15 extensions, I could get that on Enpass too. thanks
February 28, 20224 yr Author 59 minutes ago, John Doe said: the thing I am missing is that I don’t get a prompt to save new a login or updated password on Enpass. I only get the alert on iCloud Keychain. With the ios 15 extensions, I could get that on Enpass too. Right now, with iOS 15, an extension isn't likely to fix this issue. It didn't with 1Password and their native extension. However, there are a lot of good reasons to move to a native iOS extension and perhaps a future version of iOS will allow for third party integrations like this.
March 1, 20224 yr Hi @all The Enpass Extension feature for Safari iOS 15 is already in development. We are working on implementing it as a priority in upcoming versions of Enpass. Thank you for your patience in the interim! #SI-2324
