September 30, 20215 yr I am trying to save a login for a platform that requires 3 inputs: Company name - user name - password. How would I set enpass to save and autofill? Thanks,
September 30, 20215 yr Hi @DavidBoutelier Welcome to the Enpass Community! Please share the below information with me and I'll get it checked for you- The version of the Enpass App you are using The version of Enpass extension you are using The name of the website which you wish to save
October 1, 20215 yr Hi, many times, it is necessary to fill in several fields to enter a web service. For example, username, ID, date of birth, password, etc. However, I am not able to teach enPass to recognize and fill in those fields that are different from username and password. And I always have to do it manually. Is there any way to do it? It would be nice to have a way to tell enPass what specific custom fields to search and fill in a login form I am using Enpass 6.7.2 (886) on Windows 10 Thanks in advance
October 4, 20215 yr Hi @ATurkey @DavidBoutelier You can autofill multiple login details by first saving the details as Webform. When on the website, fill the fields you want Enpass to save and autofill. Then click on Enpass extension on your browser -> Hamburger Icon(Menu) -> Save Webform . This will save all the details as Webform . Next time during the autofill, please select the item of webform which you saved. Hope this helps !
