October 10, 20215 yr Hi, I am a longtime user of Enpass, but I do not know how I can get it to autofill credit cards in IOS/iPhone. The iPhone takes over and tries to use locally scanned credit cards, and doesn’t even provide the option (in the keyboard) for me to consult a password manager or even the built in iCloud keychain. I have just been switching between the Safari and the Enpass app, copying and pasting each field in the credit card, and for the next field I have to authenticate to Enpass again (because technically I closed the app…), and it is getting annoying. Help!
October 11, 20215 yr Hey @Mwaters, Let me help you with this. Follow the below-mentioned steps and do let me know if it worked for you. Go to iOS Settings--> Passwords & Accounts --> AutoFill Passwords and turn on the AutoFill Passwords. Also, make sure you select the Enpass from the provided options to allow auto-filling (as shown in the screenshot below). Enpass integrates directly into Safari as an extension and does auto-filling for you. First, you will have to enable its browser extension. Also, refer to this link from our user manual regarding Autofill with Safari Browser.
October 12, 20215 yr Author 19 hours ago, Gulshan Dogra said: Hey @Mwaters, Let me help you with this. Follow the below-mentioned steps and do let me know if it worked for you. Go to iOS Settings--> Passwords & Accounts --> AutoFill Passwords and turn on the AutoFill Passwords. Also, make sure you select the Enpass from the provided options to allow auto-filling (as shown in the screenshot below). Enpass integrates directly into Safari as an extension and does auto-filling for you. First, you will have to enable its browser extension. Also, refer to this link from our user manual regarding Autofill with Safari Browser. Hi, Autofill works fine, just not for credit cards. For instance I just autofilled my password for this site, from Safari on my iPhone. I am however still unable to autofill items from my Enpass “credit card” group into a credit card entry form in Safari. Thanks!
October 12, 20215 yr Hey @Mwaters, Please let us know the below-mentioned details so that I can get it tested for you: On which device are you using Enpass? Which version of Enpass, OS and Browser are you using? Are you facing the same problem with other browsers too? List the Web pages/sites on which you are getting this issue. Cheers!!
