February 4, 20224 yr Hello, I have a question about Enpass for 32bit debian based system. System : Quote Dell inspiron 1300, 2g ram, cpu 1.6ghz, Bunsenlabs kernel 5.10.0-0.bpo.9-686-pae Openbox 3.6.1 Enpass 5.6.9 Enpass is installed via apt (enpass repo). What happens. When I start Enpass via Alt+F2 or via the openbox menu, Enpass starts up and I can enter the password. As soon as I ENTER after filling in, the tray icon appears very quickly, but immediately disappears again, and Enpass is closed. When I start Enpass /opt/Enpass/bin/runenpass.sh %U through the terminal I don't have that problem and can use Enpass, as long as I keep the terminal open. The connection to the webapp is not possible. FF. error_ouput. I saw something pass by about 'gail' and 'atk'. Then I looked for packages with 'gail' and 'atk' and installed a few new ones. But Enpass still kills. I suspect it has to do with GNOME libraries for 32bit. My knowledge in this area is nil to go deeper into this. Because Enpass starts up via the terminal, there is no clear error showing anymore, to show. Error output where there before, which I partially solved by installing 'gai' 'atk' packages. I hope someone can give a direction to look at. Thanks in advance. Eric. some_output - unable to locate theme engine in module path "adwaita" - libpng warning: iCCP: known incorrect sRGB profile - already has layout
February 4, 20224 yr Author 56 minutes ago, musq said: Hello, I have a question about Enpass for 32bit debian based system. System : Enpass is installed via apt (enpass repo). What happens. When I start Enpass via Alt+F2 or via the openbox menu, Enpass starts up and I can enter the password. As soon as I ENTER after filling in, the tray icon appears very quickly, but immediately disappears again, and Enpass is closed. When I start Enpass /opt/Enpass/bin/runenpass.sh %U through the terminal I don't have that problem and can use Enpass, as long as I keep the terminal open. The connection to the webapp is not possible. FF. error_ouput. I saw something pass by about 'gail' and 'atk'. Then I looked for packages with 'gail' and 'atk' and installed a few new ones. But Enpass still kills. I suspect it has to do with GNOME libraries for 32bit. My knowledge in this area is nil to go deeper into this. Because Enpass starts up via the terminal, there is no clear error showing anymore, to show. Error output where there before, which I partially solved by installing 'gai' 'atk' packages. I hope someone can give a direction to look at. Thanks in advance. Eric. some_output - unable to locate theme engine in module path "adwaita" - libpng warning: iCCP: known incorrect sRGB profile - already has layout EDIT::: testing : Enpass only runs when i manually start the program from the terminal. Using &! puts the terminal to the background. This is the way i run Enpass now. Automate the process does not work. (autostart) I am glad it works somehow, but a fix would be nice, for auto start enpass at boot.
April 19, 20224 yr Hi @spcynudls, Welcome to the Enpass Community Forums. Thank you for reporting the presence of this issue. In order to assist you better, please help me with the following details: Share the details of the Enpass version, Linux OS version (32 or 64 bit). Help me with your cloud sync account information.
