March 7, 20224 yr Hi, Just moved from MYKI and noticed that a couple of my 2FA secrets that are quite long (approx 60 chars) show as invalid and don't spit out a TOTP code despite showing fine in MYKI. Is this by design, or is there a way around it?
March 8, 20224 yr Hi @DiddlySquat, Welcome to the Enpass community. As far as I have understood you are trying to set up a TOTP code for 2FA supported websites and you are getting an "invalid secret key" error. If this is the case, then I would like to share that the standard TOTP length for Enpass is 6 digits by design.
March 8, 20224 yr Author Hi, That’s correct. It is still a 6 digit TOTP code however and MYKI did this fine. like I said, I had 2 TOTP secrets that were working in MYKI but not in Enpass, and the only thing that was similar with these two secrets and unlike any of my other TOTP codes was the length. Most of my TOTP codes are about 25 characters or less, but this one was more around 60 or so.
