Is Egde on Linux supported?
Is get error 403, The diag is:
  • code : 2
  • origin : chrome-extension://mliehcloacfoicbanjhhnlimealolgoi
  • path : msedge (/opt/microsoft/msedge/msedge)
  • pid : 1493
  • port : 56512
  • server_port : 10391
lsof -i:10391
COMMAND  PID  USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
Enpass  1183 toine   31u  IPv4  27587      0t0  TCP localhost:10391 (LISTEN)
What can I do to correct it?
BR Toine
Hi @BlackhillOne,
Welcome to the Enpass community.
Yes, This error might occur in a mixed environment when the browser is running recently updated in the background and newly open browser windows/tabs use the updated version. Please restart your browser. If any authorization/pairing prompt is shown, please complete the process.
Also, disable and enable the Browser extension from the Browser settings of the Enpass app.
If the problem persists, please let us know the following so that we can help you better.
  1. On which device (along with OS version) are you using Enpass?
  2. Share the versions of the Enpass App, Enpass Extension, and Chrome version you are using?
  3. Are you facing the same problem with other browsers too?
  4. Are you using any Antivirus or third-party security-related extension?
