March 13, 20188 yr Enpass doesn't search by few separated words (record named 'john smith card' not found by typing 'john card' in search bar). This is a big headache if you have hundreds of passwords. Can you add this feature in a future releases?
March 19, 20188 yr Hi @Evgenii Z, Thanks for your suggestion. I've noted it for consideration. Cheers!
July 21, 20188 yr On 3/13/2018 at 11:03 AM, Evgenii Z said: Enpass doesn't search by few separated words (record named 'john smith card' not found by typing 'john card' in search bar). This is a big headache if you have hundreds of passwords. Can you add this feature in a future releases? +1 This is actually kind of a big deal when you have more that a few entries. It's quite surprising that Enpass search function doesn't yet distinguish between the "space" key and any other character. It would be like forcing a case sensitive search, but instead of having to remember the exact way you wrote something, you now need to remember the exact word sequence. Plus the exact way you wrote the word before the space. Otherwise, as soon as you hit space, the entire list of results goes blank. For example, let's consider a database that has this 2 items: "email personal" and "workplace email". I also have 15 other elements containing the word "workplace" and 10 others containing the word email. Let's say now that we want to quickly isolate "workplace email". Let's also suppose that i don't remember wether I wrote "work email", "email work", "workplace email", "workplace one email" etc.. You get the idea. At the moment, queries like "email work" "email workplace" "work email" "workplace mail" would all return no result. The only way to get to our "workplace email" would be to either type it exactly, or typing something like "work" and scroll the results trying to find the exact one. There is clearly an issue. Just something as quick as ignoring the "space" in the search query should help. Please, report to the devs.
