June 3, 20224 yr Hello team, Is it possible to implement the ability to refer to a field from an existing item to a new item? For example, I have an AD account for multiple applications. I need to change this password every 90 days and it's not easy to change all passwords item for all applications. Thanks. Xillion
June 6, 20224 yr Hi @xillion, Welcome to the Enpass community. I appreciate your efforts for taking time to explore our app and sharing your feedback with us. Currently it is not possible but I have duly noted your point and your suggestion has been forwarded to our concerned team for further consideration. #SI-2906
November 11, 20224 yr Hi @xillion Your request has already been forwarded to our developers and I would like to inform you that they have investigated its feasibility. This feature request may be included in future Enpass releases even though we have not yet received any specific version updates. Your support and patience are greatly appreciated.
May 1, 20242 yr Enpass Team, is there any update on this request. It's been a while now. FWIW, I am having to use KeePassXC for this specific use case and would love to be able to have all my passwords in one place instead.
