July 25, 20224 yr Issue with enpass 6.8.1 (1063) on ubuntu (installed trough your repo) and android 6.8.2.666. This is fresh install so nothing to delete, here is the result of litmus ( http://www.webdav.org/neon/litmus/ ) test result, as it is official tool for testing webdav compliance, it proves there is nothing wrong with my server. litmus https://server.eu/somewhere/webdav username "password" -> running `basic': 0. init.................. pass 1. begin................. pass 2. options............... pass 3. put_get............... pass 4. put_get_utf8_segment.. pass 5. put_no_parent......... pass 6. mkcol_over_plain...... pass 7. delete................ pass 8. delete_null........... pass 9. delete_fragment....... pass 10. mkcol................. pass 11. mkcol_again........... pass 12. delete_coll........... pass 13. mkcol_no_parent....... pass 14. mkcol_with_body....... pass 15. finish................ pass <- summary for `basic': of 16 tests run: 16 passed, 0 failed. 100.0% -> running `copymove': 0. init.................. pass 1. begin................. pass 2. copy_init............. pass 3. copy_simple........... pass 4. copy_overwrite........ pass 5. copy_nodestcoll....... pass 6. copy_cleanup.......... pass 7. copy_coll............. pass 8. copy_shallow.......... pass 9. move.................. pass 10. move_coll............. pass 11. move_cleanup.......... pass 12. finish................ pass <- summary for `copymove': of 13 tests run: 13 passed, 0 failed. 100.0% -> running `props': 0. init.................. pass 1. begin................. pass 2. propfind_invalid...... pass 3. propfind_invalid2..... pass 4. propfind_d0........... pass 5. propinit.............. pass 6. propset............... pass 7. propget............... pass 8. propextended.......... pass 9. propmove.............. pass 10. propget............... pass 11. propdeletes........... pass 12. propget............... pass 13. propreplace........... pass 14. propget............... pass 15. propnullns............ pass 16. propget............... pass 17. prophighunicode....... pass 18. propget............... pass 19. propremoveset......... pass 20. propget............... pass 21. propsetremove......... pass 22. propget............... pass 23. propvalnspace......... pass 24. propwformed........... pass 25. propinit.............. pass 26. propmanyns............ pass 27. propget............... pass 28. propcleanup........... pass 29. finish................ pass <- summary for `props': of 30 tests run: 30 passed, 0 failed. 100.0% -> running `locks': 0. init.................. pass 1. begin................. pass 2. options............... pass 3. precond............... pass 4. init_locks............ pass 5. put................... pass 6. lock_excl............. pass 7. discover.............. pass 8. refresh............... pass 9. notowner_modify....... pass 10. notowner_lock......... pass 11. owner_modify.......... pass 12. notowner_modify....... pass 13. notowner_lock......... pass 14. copy.................. pass 15. cond_put.............. pass 16. fail_cond_put......... pass 17. cond_put_with_not..... pass 18. cond_put_corrupt_token WARNING: PUT failed with 400 not 423 ...................... pass (with 1 warning) 19. complex_cond_put...... pass 20. fail_complex_cond_put. pass 21. unlock................ pass 22. fail_cond_put_unlocked pass 23. lock_shared........... pass 24. notowner_modify....... pass 25. notowner_lock......... pass 26. owner_modify.......... pass 27. double_sharedlock..... pass 28. notowner_modify....... pass 29. notowner_lock......... pass 30. unlock................ pass 31. prep_collection....... pass 32. lock_collection....... pass 33. owner_modify.......... pass 34. notowner_modify....... pass 35. refresh............... pass 36. indirect_refresh...... pass 37. unlock................ pass 38. unmapped_lock......... WARNING: LOCK on unmapped url returned 200 not 201 (RFC4918:S7.3) ...................... pass (with 1 warning) 39. unlock................ pass 40. finish................ pass <- summary for `locks': of 41 tests run: 41 passed, 0 failed. 100.0% -> 2 warnings were issued. -> running `http': 0. init.................. pass 1. begin................. pass 2. expect100............. SKIPPED (skipping for SSL server) 3. finish................ pass -> 1 test was skipped. <- summary for `http': of 3 tests run: 3 passed, 0 failed. 100.0% Edited July 25, 20224 yr by microg
July 25, 20224 yr Author Furthermore, here are access logs from my apache 2.4 server access logs: 10.1.0.1 - - [25/Jul/2022:21:12:21 +0200] "PROPFIND /somewhere/webdav/ HTTP/1.1" 401 381 10.1.0.1 - - [25/Jul/2022:21:12:21 +0200] "PROPFIND /somewhere/webdav/ HTTP/1.1" 401 381 10.1.0.1 - username [25/Jul/2022:21:12:21 +0200] "PROPFIND /somewhere/webdav/ HTTP/1.1" 405 225 10.1.0.1 - - [25/Jul/2022:21:12:21 +0200] "PROPFIND /somewhere/webdav/ HTTP/1.1" 401 381 10.1.0.1 - username [25/Jul/2022:21:12:21 +0200] "PROPFIND /somewhere/webdav/ HTTP/1.1" 405 225 I am using mod_webdav without any additional software. Edited July 25, 20224 yr by microg
July 25, 20224 yr Author And here is apache 2.4 configuration, dont forget to enable dav modules in main httpd.conf file (and verify you have them installed): (I am on freebsd 13, adjust parts based on your operating system) LoadModule dav_module libexec/apache24/mod_dav.so LoadModule dav_fs_module libexec/apache24/mod_dav_fs.so LoadModule dav_lock_module libexec/apache24/mod_dav_lock.so Configuration of host (I am using https and I would suggest you do to, but I wont go into details, here is for http, for https search google and change Listen and VirtualHost lines to port 443). Listen 80 ExtendedStatus On Protocols h2 http/1.1 <VirtualHost 10.1.0.1:80> ServerName 10.1.0.1 DocumentRoot /usr/local/www/apache24/data ErrorLog /var/log/httpd-error.log CustomLog /var/log/httpd-access.log common DavLockDB /data/DavLock Alias /somewhere/webdav /data/webdav # you need to set permissions correctly i.e.: `chown -R www:www /data` and `chmod -R ug+rwx /data`!!!! <Location /somewhere/webdav> DAV On DirectoryIndex index.html AuthType Basic AuthName "Password Required" AuthUserFile /usr/local/etc/apache24/webdav.passwd #create `username` with `htpasswd -c /usr/local/etc/apache24/webdav.passwd username` Require user username # insert correct "username" set up in previos step here </Location> </VirtualHost> Edited July 26, 20224 yr by microg
July 25, 20224 yr Author Bottom line, it should be seen from the apache logs that you are getting back 405, I would believe that you are authenticating in wrong manner or something. The webdav test tool (from webdav.org) doesnt have those issues.
July 26, 20224 yr Author Ok, after some tracking of bugs on apache 2.4, it looks like it is its fault. Setting DirectoryIndex messes up webdav, fix in upper configuration is: DirectoryIndex disabled This is one of relevant bugs: https://bz.apache.org/bugzilla/show_bug.cgi?id=54914 Anyway this was fixed in apache 2.5 but got never merged into 2.4. It is a nasty bug that isnt very apparent, so it is quite possible that even 3rd party providers are not aware of it. To the Enpass team: with more logging you would avoid so many "webdav doesnt work" messages, and your spam protection on this forum really sucks. Captchas are pain in the neck, while your spam protection is worse, I wasted hell of a lot of time to get those messages here. And for god sake, implement already sftp sync, it is taking for years, if you have implemented piece of shit like webdav, sftp should be easier. You have bunch of 3rd party libraries on the internet, just use one. Edited July 26, 20224 yr by microg
July 26, 20224 yr Hi @microg Thank you for notifying me that the issue you were facing got fixed in apache 2.5. Moreover, we’re always excited to welcome valuable suggestions from our users and entertain users requests for new features. Your inputs have been forwarded to our dedicated team for further consideration. We appreciate your patience in the meantime.
