July 26, 20224 yr Hello there On multiple sites i've got the problem, that MFA Code is not filled in automatically. Login works - but the 6digit code isn't recognized by enpass. So i have to get the code manually everytime and fill in the section. Coworkers have 1password and for them its working automatically. Anybody a solution for this? Thank you in advance
July 27, 20224 yr Hi @AndriDe, Welcome to the Enpass community. Please let us know the following details so that we can help you better in this. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Are you facing the same problem with other browsers too? On which Web pages/sites you are getting this issue?
July 27, 20224 yr On all platforms, Enpass has a setting that's on by default, that copies and maintains the TOTP if the corresponding item has been chosen for autofill. So you should never have to copy, only paste, which isn't that time consuming. if you're into fiddeling (and depending on the platform) you can also setup different shortcuts to the Paste command, like the middle button of the mouse.. having that said, I don't if the developers actively try to improve autofill for TOTP as the do with username+password. They'll have to answer for that. frankly i just wish they implemented Autotype-functionality as an option which would make Enpass be able to autofill native applications and break the dependency of a browser plugin all in all. but thats another fairytale.. (your question is a bit misplaced though, it belong in this category)
