March 21, 20188 yr I think, it would be better if attachments (files) would be saved in a separate encrypted database (linked by a record id with main?). It will keep main data file small enough and syncronization will be faster, as attachments aren't changed often. Edited March 21, 20188 yr by DeadMoroz
March 22, 20188 yr Hi @DeadMoroz, Thanks for your suggestion. The suggested feature is already planned for the next major update. Cheers!
