August 25, 20224 yr Everything I run except Enpass handles scaling the interface when I switch from one monitor that for instance is using 150% scaling to my laptops integrated monitor that uses 100% (I'm not draging the window over I use an external monitor that I physically disconnect). The interface in Enpass in that case will be huge or if the situation is reversed it will be tiny. Is this a known issue? Any solutions?
August 26, 20224 yr Hi @agent92 It seems that Enpass is picking the wrong scale factor for your display. Please refer to our handy guide on correcting the Enpass display. If the issue persists, please share the below details with me and I'll have this further investigated for you - The version of the Enpass app and OS you are using. A screenshot of the incorrect display would be helpful.
