October 5, 20224 yr I just don't know what I'm doing wrong. I have my settings correct and enpass is enabled in accessibility, but it still doesn't detecr password fields and autofills in my info. Can someone help me troubleshoot please? Thanks in advance.
October 6, 20224 yr you should mention your device your android version your enpass version I've seen several times that the "Autofill using Accessibility" is broken when you go into the system menu, a few enalbe/disable and it might start work again. But the Autofill service should work. What keyboard are you using, have you tried another one?
October 6, 20224 yr S21 Ultra Android 12 Enpass 6.8.3.726 I was originally using the Yandex Keyboard but have swapped to Grammarly to try some new stuff out. Hasn't seemed to make a difference.
October 7, 20224 yr Hey @IGS, Thank you for reporting this issue. From your shared details everything seems to be correct for autofill. The only thing that I can suggest here is the reinstallation of the app. Kindly, take a backup of your data or sync it with a cloud account and reinstall the app. I have also, shared it with the concerned team for further investigation. In the meantime, please try the above steps and share your finding.
