November 19, 20224 yr Dropbox sync with the Linux Enpass client has stopped working for me for a couple of weeks. Don't get any errors in log. It just doesn't sync. I've tried to disconnect the vault from Dropbox, but didn't work. Nothing happened. So, then after I backed up my vault, I tried to uninstall, remove my old vault and settings manually, and then reinstall. But when reinstalling it still won't sync with Dropbox. Dropbox sync still works for me between other devices (Windows and android). Not sure what to do to fix this. Distribution: Fedora Linux 36 (Workstation Edition) Enpass version: 6.8.4.1167
November 21, 20224 yr Hi @Quirk Welcome to the Enpass Forums. Please try the below steps and share your findings with me - Take a backup of the Enpass Data on your device. Erase Everything from Enpass Settings -> Advanced -> Reset Enpass. Restore using the backup file. Sync the Vault with the Dropbox Account. Let me know if the issue persists.
November 6, 20233 yr it stopped working. I was able to set up enpass, but without dropbox sync. tried flathub and RPM. Tried chrome and firefox. Enpass is showing loading, after clicking allow... oh. It synced, but after like 10th attempt... and only after setting up Enpass from backup. Distribution: Fedora Linux 38 (Workstation Edition) Enpass version: 6.9.1 (1511)
