January 7, 20233 yr Hi. My use case is that I use Enpass to share passwords with my wife. I have created a secondary vault (on Dropbox) that I share with her because it is not possibly to share an additional vault on the same drive (iCloud, Dropbox or Onedrive actually, I tested them all). That’s a shame because I am paying for iCloud because I believe their security is better than Dropbox especially with their new end to end encryption. So I would like to share a secondary vault on iCloud but it is not possible. Could you please consider the creation of secondary vaults on the same drive service? Thank you.
January 9, 20233 yr Hi @Laurent When using multiple vaults in Enpass, each vault must be connected to a separate cloud account for syncing. It is not possible to connect more than one vault with the same cloud account. (You can still use the same cloud service by creating a different cloud account) However, if you are using WebDAV/OwnCloud, sync with multiple vaults is possible by defining separate paths/folders for each vault.
May 20, 20233 yr Author Could you please add this in your roadmap? It would be very nice to be able to share easily one additional vault on the same cloud with relatives. Thank you. Edited May 20, 20233 yr by Laurent
May 22, 20233 yr Hi @Laurent Enpass is always grateful for our active users and your efforts in notifying us of this feature. I forwarded this request to our developers and would like to inform you that they have investigated its feasibility & unfortunately, this request cannot be taken into consideration at the moment. Your support and effort are greatly appreciated. However, if you are using WebDAV/OwnCloud, sync with multiple vaults is possible by defining separate paths/folders for each vault. Also, to share Items with your relatives, you can also refer to our handy guide.
