Sort suggestions based on subdomain
I know that Enpass has a feature to only match subdomain for suggested credentials, but that can lead to other problems: you register on a site on www.domain.com but when you login the subdomai is auth.domain.com
So it cannot be used. But what can be done is this:
Make a feature so that the top of the suggested credentials matches the subdomain that they were created.
So that you don't have to search through the list; it can be frustrating if you have alot of credentials for a top level domain.
Alex
Hi @Alexandros
I have duly noted your comments and have shared them with our dedicated development team so they may consider this feature request for future Enpass versions. Your patience in the meantime is appreciated.
#SI-3311
